Coil pack conversion
Old Dec 11, 2006 | 09:01 PM
cosrep's Avatar
cosrep
Default Coil pack conversion
Looking to get the conversion done soon but have several questions.
1) Is the coil pack supplied in the kits the same as the one fitted to a zetec engine cos I have one lying around?
2) I have a 92 saff 4x4, do I need the rev counter modded? If so how difficult is it to do?
3) Will a secs monitor be affected by the conversion?
Old Dec 11, 2006 | 09:04 PM
rapidcossie's Avatar
rapidcossie
i have zetec coil pack on mine..
you will need a driver for the ecu
not sure about rev counter but something needs modded i think
Old Dec 16, 2006 | 05:23 PM
Twellsie's Avatar
Twellsie
in this months fast ford there is an article about fitting a coil pack, and yes you do need to do a slight mod to the rev counter, just a case of soldering a small bit of wire to a couple of the point on the back of the counter, if you buy the mag there is a pic showing exactly where
Old Dec 23, 2006 | 12:18 PM
Kiwi_Cossie's Avatar
Kiwi_Cossie
I saw that article, was thinking about getting it done to my 3 door, just wondering has anyone else had it done and is it worth the effort.
Old Dec 23, 2006 | 12:21 PM
Stu @ M Developments's Avatar
PassionFords Creator
There are a lot of PF members have it, maybe worth putting a topic in general discussion to get a good selection of independant opinions.
Old Dec 23, 2006 | 03:49 PM
Kiwi_Cossie
Fair one Stu, how much do you charge to do the whole thing? Will it work with an original 3 door ECU?
P.S. sorry about hijacking your thread cosrep!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
