Playing with my knob!!!!!!!!!!
Old Sep 1, 2004 | 06:00 PM
woodz77's Avatar
woodz77
Default Playing with my knob!!!!!!!!!!
i bought myself a chrome gear knob today but when i came to take off mine (mk5 rs 2000) it wont come off. ive tryed twisting it to the left , then the right but it doesnt want to undo. im i doing it wrong or do i need to use super human power! it has a lift up reverse.
Old Sep 1, 2004 | 06:03 PM
whitneyd's Avatar
whitneyd
It takes a lot of turns then pull it off.
Old Sep 1, 2004 | 06:08 PM
kevandalice's Avatar
kevandalice
dont turn it, pull it HARD
Old Sep 1, 2004 | 06:24 PM
woodz77's Avatar
woodz77
shall i pull it or turn it whos right ?????
Old Sep 1, 2004 | 06:41 PM
whitneyd's Avatar
whitneyd
I did both. Turned then pulled.
Old Sep 1, 2004 | 07:03 PM
kevandalice
trust me you pull it, dont twist as you may damage the knob. ive actually changed my gearknob on the same car.
Old Sep 1, 2004 | 07:04 PM
Stu.H's Avatar
Stu.H
cut the fooker off and then fit new one
short shift stylee
Old Sep 1, 2004 | 07:14 PM
woodz77's Avatar
woodz77
ive got the black knob off but theres like a had plastic knob thing underneath. if i cut this off will it effect the lift up reverse feature.cause the plastic thing has got any screws holding it on so i cant see any other way of getting it off, but cutting and ripping it off. i just dont want the reverse thing to f**k up????
Old Sep 1, 2004 | 10:31 PM
Orionzetec's Avatar
Orionzetec
Ask this question on the forum over at http://www.rs20004x4.com
They all great peeps and will awnser your q in a few seconds
Old Sep 1, 2004 | 10:54 PM
Jim Galbally's Avatar
Jim Galbally
twisting can snap the lift up reverse...
i found this out on my old XR4x4
get a BIG pair of pliers n pull the fucker off...
if that fails... get the hacksaw out n cut it off
Old Sep 2, 2004 | 01:02 AM
rs_daz's Avatar
rs_daz
yeh best to pull it off no twist ,once thats off ur see how its all put together
Old Sep 2, 2004 | 05:26 AM
woodz77's Avatar
woodz77
excellant .i will try this cheers mates!!
Old Sep 2, 2004 | 06:53 AM
Joris_FRST's Avatar
Joris_FRST
There is a little pin in the back under the rubber.
Old Sep 2, 2004 | 09:07 AM
nomad's Avatar
nomad
you should leave the hard plastic bit on, the new gearknob should fit over this and is held in place by an allen key, (ours do)
cheers nomad
martynhomer01
14
Sep 23, 2015 12:23 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Cos500
Sep 16, 2015 09:50 PM
21
Sep 14, 2015 06:38 PM
ST-170
Sep 4, 2015 11:02 AM
