Temp gauge fitting?
As above really i have a nomad water temp gauge to install but noit sure wheres the best place to put the sender?
I had thought about putting it in the pipe where my swirl pot is with a connector from tweekies. Then i wondered if i could use the hole where the standard temp sensor is[blue one at back of engine by dip stick]by using a T piece.
Anybody have and ideas?
mrmann
Aug 20, 2015 11:24 PM
COSWORLD
Aug 14, 2015 07:40 AM
