Whats wrong god dammit
Old Dec 11, 2006 | 05:43 PM
Dragsteer's Avatar
Dragsteer
Default Whats wrong god dammit
Yesterday I was clean little hoses, amal valve-turbo, amal valve-wastegate, engine-ic, turbo-air filter.
and today car wpnt start, and I turn on engine after 5 mins, then rpms wont stay at normal, thet go down and engine turns off.
and engine is to hot I think after few km.
HELP please
P.S. Is this correct : amal valve lower hose----goes to wastegate
amal valve upper hose----goes to turbo
Old Dec 11, 2006 | 05:50 PM
batrst's Avatar
batrst
sounds like yo got an air leek
Old Dec 11, 2006 | 06:26 PM
davidnormanuk's Avatar
davidnormanuk
Old Dec 11, 2006 | 08:44 PM
ianshad6's Avatar
ianshad6
what happen to the air box it you go EFI????or do you blank it off????????sorry if it sound dumb?
Old Dec 11, 2006 | 10:06 PM
Dragsteer's Avatar
Dragsteer
batrst: i was have air leak. my hose which goes from air box to turbo was not "sticked" properly, air leak was in right part of hose (closer to air box).
now rpms is ok.
but...
davidnormanuk: thanks abput picture, but my amal valve is not wired like this. what will happen if hose which must go to actuator, go in turbo??
Old Dec 11, 2006 | 10:50 PM
batrst's Avatar
batrst
thats how mine is mate
got no amal valve you dont need it
you can run same boost all the time
just make sure pipes are good tite fit
Old Dec 11, 2006 | 11:53 PM
Dragsteer's Avatar
Dragsteer
batrst: i put hoses how you say and how car goes like crazy!!
thank you mate!
p.s. what if i remove amal valve? i will have 0.5 all the time? but tis is no good for turbo? will car go better if no amal?
and my exhaust mainfold is broken on few places, is possible that turbo spin about 0.4 because of this? My spark plug cables are hooot and they are under exh mainfold , maybe they are hot because off exh mainf leak?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
