S1 not starting...
Old Dec 10, 2006 | 04:44 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Default S1 not starting...
Went to start up the S1 today, just to make sure she's still sweet, fully charged battery, petrol in, fuel pump priming fine, getting a spark but just wont start, just turns over
Any ideas??? Was running like a dream about 2 months ago but not been at it
Old Dec 10, 2006 | 06:22 PM
turboloon's Avatar
turboloon
Default flooded
sounds as though it could be flooded...pull a plug if it is wet it will be flooded pull the plugs dry them off then pull the fuel pump relayput the plugs back in and turn it over then hopefully that should burn of the excess fuel then reinstall the relay hopefully that should get your car running then leave it to run for a good 10 mins.
Old Dec 11, 2006 | 12:45 AM
SafeChav's Avatar
SafeChav
Is the pump priming when you turn on and/or running when you crank over?
Have you checked for fuel from the injectors?
Old Dec 11, 2006 | 01:47 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if all of the above is ok, disconnect cold start, take airbox off and give it a WEE helping hand, press the metering flap down about 5 mm while someone is cranking!
peter316
Apr 27, 2012 05:26 PM
Rsmat
268
Apr 11, 2012 05:06 PM
ScORTED
Oct 30, 2005 06:02 PM
ScORTED
Oct 27, 2005 09:34 PM
james_birch
Jun 6, 2005 10:00 PM
