Oil Separator / Breather
Old Dec 10, 2006 | 04:16 PM
psychoeric's Avatar
psychoeric
Default Oil Separator / Breather
Could anyone let me know whether I should keep or remove the kidney box when fitting an aftermarket breather, such as a bailey etc.
What are the advantages of keeping or removing it?
Old Dec 11, 2006 | 02:07 PM
KSA-Cossie's Avatar
KSA-Cossie
I was told to keep it on m8.
Old Dec 11, 2006 | 02:24 PM
Daxcossie's Avatar
Daxcossie
The best way forward is to remove the kidney box, BUT this should only be done if you can feed the oil return to the sump.
If you return the oil to the sump, it will then free up the oil return on the block to act as an additional breather to your tank. Dont bother to breath from the rocker cover.
The problem with returning the oil to the block is that there is pressure in the crank case whilst the engine is running, so it can only drain when the engine is stopped. There is no pressure in the sump, so it will be draining whilst running, meaning the after market tank will not fill up causing excessive oil blow from atmosphere pipe on the set-up.
Hope that helps.
PS - You can get a connection to replace the sump plug with an oil return plug.
Old Dec 11, 2006 | 06:00 PM
psychoeric's Avatar
psychoeric
Thanks for your help
Richard
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
