Not boosting Properly and Stutter.
Old Dec 8, 2006 | 02:04 PM
J9BBY's Avatar
J9BBY
Default Not boosting Properly and Stutter.
Just had head skimmed and put new head gasket on. Car now does not boost over 15psi and has a bit of a stutter higher in the revs.
Before I did the head it was boosting fine up to 29psi with no stutter. I have not changed anything else since this.
All usual bits were changed before head was done (leads, dizzy cap, rotor arm plugs gapped to 0.65mm etc).
Could it be a punctured boost/vaccuum hose? No noticable hissing.
At a bit of a loss on this one....
Pete.
Old Dec 23, 2006 | 08:28 PM
philbert's Avatar
philbert
Default not boosting
Have a look at the exhaust manifold gasket and the turbo to manifold gasket and check bolts also
Old Dec 27, 2006 | 10:48 AM
Twellsie's Avatar
Twellsie
how much have you had the head skimmed by?
Old Jan 12, 2007 | 10:00 AM
J9BBY's Avatar
J9BBY
Just had a small amount taken off the head, but it has had a hard life before me. Not measured it but has had a lot skimmed off, machinist bloke mentioned this also. Compression ok.
Have since changed vacuum hoses, still no change.
Turbo/manifold all bolted up ok but noticed quite a few, large, hairline cracks in the exhaust manifold. Could this be the problem? No stutter when not on boost.
Will the boosting problem and stutter be seperate?
HELP!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
ajamesc
Sep 8, 2015 06:51 PM
