can anyone reccomend some settings for coilovers?
Old Sep 1, 2004 | 10:12 AM
Jim Galbally's Avatar
Jim Galbally
Default can anyone reccomend some settings for coilovers?
ie what to set em to before fitting...
i was thinking -25mm (whatever that is adjustment wise) and medium stiffness?
sound about right?
Old Sep 1, 2004 | 10:15 AM
Spiky's Avatar
Spiky
coilovers
YOU set them up as YOU want them
Old Sep 1, 2004 | 10:17 AM
Jim Galbally
yes spiky, but i'll want a base to work from...
gonna be sorted by zoo on the 18th (hopefully) but until then i'll want something to work from.
Rene's Avatar
Rene
Originally Posted by Spiky
coilovers
ok james
Old Sep 1, 2004 | 10:19 AM
Spiky's Avatar
Spiky
coilovers
ok james
pmsl
jim a base???
like i said they are custom....YOU decide
here is how mine was setup
Old Sep 1, 2004 | 10:22 AM
Jim Galbally
did you have problems with full lock, reversing, or ground clearance or were they stiff enuf not to be a problem?
Old Sep 1, 2004 | 10:25 AM
Spiky's Avatar
Spiky
none, apart from the ODD speed bumps, which just slightly caught the centre box
full lock was fine
reversing???? what difference does that make
Old Sep 1, 2004 | 10:26 AM
Daveyboy's Avatar
Daveyboy
innit!!
Old Sep 1, 2004 | 10:28 AM
Rene's Avatar
Rene
well going backward instead of forwards?
Old Sep 1, 2004 | 10:29 AM
Spiky's Avatar
Spiky
still dont understand though
Old Sep 1, 2004 | 10:47 AM
Jim Galbally
mine catches the arch when reversing on full lock, but not when going forwards on full lock (well, it catches, but not badly)
but then i do have about 2mm clearance between arch and tyre
Old Sep 1, 2004 | 10:48 AM
Spiky's Avatar
Spiky
mmmm something not quite right there dude
Old Sep 1, 2004 | 10:52 AM
Jim Galbally
i think that its because when youre going forwards the tyre it hitting the arch on the smooth bit where it meets the wing, so it glides over with just a bit of creeking... but when youre going back its getting caught on the open lip...
Old Sep 1, 2004 | 10:55 AM
Jim Galbally
ive just thoght about what i just said and it doesnt make sense
might get someone to watch me reverse on full lock later to see what catches
Old Sep 1, 2004 | 10:57 AM
Spiky's Avatar
Spiky
the inner plastic did touch on full lock, but only one one side, cos it was fooked
Old Sep 1, 2004 | 11:00 AM
Jim Galbally
i'll make sure to check the arch liner then
yatta
May 21, 2016 10:31 PM
S3an
Sep 26, 2015 11:39 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
S3an
13
Sep 13, 2015 10:01 AM
Adam Graham
Sep 6, 2015 06:04 AM
