Does anyone know about Samco coolant hoses on a T3 conversion on a Fiesta RST? I was told that the fiesta kit won't fit. However some people say that it will. Any ideas?
Its better to block the water returns off on the turbo and the pipe work with bolts and jubilee clips and just run oil cooled the same as the series one, i do this to mine as the engine temps are reduced as the water isn't running through the turbo, boiling up then running through the engine again, you just have run up and down for the correct amount of time 2-3 mins.
