2nd Fuel Pump Relay In the Boot??
Old Dec 6, 2006 | 09:15 AM
Diablo's Avatar
Diablo
Default 2nd Fuel Pump Relay In the Boot??
Does anyone know why some Cosworth's have a second fuel pump relay wired in, usually in the boot? I am having some trouble with my fuel system, and I cannot figure out why an additional one is needed?
Thanks in advance
Old Dec 6, 2006 | 11:04 AM
TurboShed's Avatar
TurboShed
Cossiemodo
You don't mean the cutoff switch in the boot?
Old Dec 6, 2006 | 11:13 AM
Diablo's Avatar
Diablo
No, I am pretty sure that RS500's don't have an inertia switch. This is a seperate 40A realy wired into the original fuel pump wiring coming from the original relay at the front of the car.
Old Dec 6, 2006 | 12:40 PM
jon@work's Avatar
jon@work
One typical cossie problem is the reduced voltage at the fuel pump due to the high resistance of the old wiring/connections. This results in poor fuel feed to the fuel rail. Using the old fuel pump feed to switch a new relay in the boot allows the pump to take a new (fused) feed straight from the battery.
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
gcfcos
88
Sep 15, 2015 03:48 PM
chris m1
Sep 7, 2015 08:02 PM
