Help: Cossie fuelling hint??
Old Dec 4, 2006 | 07:05 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Help: Cossie fuelling hint??
As some of you will know I have a fuelling problem with my sierra cosworth 4x4. Step by step I try to find out what causes this to get so lean like it is now. I discovered this at a rolling road session 2 months ago.
Well I tried numerous things like :
fuel pump wiring (after new wiring the voltage went up from 11,5V to 12,9 V),
new fuel filter,
checked the fuel lines,
fuel pressure check,
new map sensor,
new rotor and distributor cap,
checked the timing,
checked the TPS,
measured the CTS and inlet air sensor
All seem ok..
This weekend i fired her up again and what I noticed was that idling when cold was ok. But as soon as you hit the throttle it seems it only gets air sucked in and no fuel (don't know how this is called in english).
My first thought about this is the CTS (although I had measured the resistant when the engine was cold and the value matched the service manual requirement).
So has anyone had this problem and maybe can give me a hint??
Because I don't know where to look for anymore...
Old Dec 4, 2006 | 07:14 PM
rapidcossie's Avatar
rapidcossie
wiring to map sensor went on mine ...
worth checking
Old Dec 4, 2006 | 07:24 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks, but did you car run very bad with this wiring problem?
In my case I can just drive the car normally and can also give it some stick. It just feel 'sluggish' (?) when you want to drive away.
At the rolling road it turned out that through the whole rev range it had some serious fuel starvation.... (afr started at 16.6 (!) at 2400 RPM and at peak power (5200 rpm) it was still 13,6 (!!) )
Old Dec 6, 2006 | 04:10 AM
Default problems
I would check your cam timing as the peak power is way way too low at 5200, it is normally at 6000 plus.
Look particularly at inlet cam timing.
Old Dec 6, 2006 | 07:13 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Hi, yes already checked the cam timing and only the distributor gear was 1 teeth out of time.. But thanks for the advice.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
Si B
Sep 12, 2015 06:49 AM
