Service Time
Old Dec 3, 2006 | 09:14 PM
mentalasanything's Avatar
mentalasanything
Default Service Time
Well, I just got my first S2 and I love it! To make sure she stays in tip top condition I plan to gice her a service.
As I'm new to all this turbo stuff, I just want to ask a few questions before I rush out and buy the wrong stuff. Also as I cant get the forum search option to work???
1) It currently has 5w50 Motorsport oil in it (Halfords Branded) is this correct? One of the followers is a tiny bit tappy and it was supposed to have been rebuilt 1000 miles ago, so would it benefit from a different grade oil?
2) Is it best to fit Motorcraft parts (Oil filter, plugs, fuel filter)?
Cheers in advance, any help appreciated!
Lee
Old Dec 3, 2006 | 09:17 PM
tuszi's Avatar
tuszi
the pluggs is best from motorcraft i heard. they recommend them on cossies and rs if i remember right
Old Dec 4, 2006 | 07:18 AM
mentalasanything
Kool, so anyone got any suggestions on the Oil? What do you guys all use??
Old Dec 4, 2006 | 07:22 AM
MJC's Avatar
MJC
I would say the oil you are using is a little thin for the CVH engine. What is the spec of the engine and how do you use it?
I currently use Silkolene 10W 50 in mine
Old Dec 4, 2006 | 07:24 AM
antony215's Avatar
antony215
Escort Rs Turbo
If it's a standard engine then 5/40 oil will be fine that's what i use in mine
Old Dec 4, 2006 | 08:47 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Originally Posted by MJC
I would say the oil you are using is a little thin for the CVH engine. I currently use Silkolene 10W 50 in mine
Agreed. I use this oil and this grade. 5w is a bit thin in my opinion.
I also use standard Ford RST plugs and might aswell get the oil filter from there too while you are at it. Which is exactly what I going to buy today.
Old Dec 4, 2006 | 11:52 AM
mentalasanything
OK kool, I thought 5w50 was a bit thin . I shall get some 10w50 today along with motorcraft plugs and oil filter!! It's a standard engine apart from a kent cam, stg1 hybrid turbo, -31 actuator and DV
Cheers Guy's
Lee
Old Dec 4, 2006 | 04:09 PM
bigchez's Avatar
bigchez
I have been adv to use 10w60 oil.
Old Dec 4, 2006 | 04:17 PM
addiction's Avatar
addiction
mobil one 15w50 motorsport oil,gen ford filter and ngk plugs
Old Dec 4, 2006 | 04:37 PM
mentalasanything
Come on Lads, I'm confused now.
everyone has preferences of their own I suppose. 10w50 is rare so how bout....
Mobil1 15w50
or Valvoline 15w50 ????
I need help!!!!!!!!!!!!!
Lee
Old Dec 4, 2006 | 04:46 PM
addiction's Avatar
addiction
Old Dec 4, 2006 | 05:04 PM
antony215's Avatar
antony215
Escort Rs Turbo
Mate give the oilman on here a PM he will tell you exactly what grade oil to use for your engine and spec
https://passionford.com/forum/profil...rofile&u=14407
Old Dec 4, 2006 | 05:54 PM
mentalasanything
Just dropped him a PM, I'm sure he'll be able to help! I ordered up the plugs oil filter and a few other parts at my local fords tonight so I can hopefully service it at the weekend!
Cheers for your help lads!
Lee
Old Dec 5, 2006 | 07:19 PM
Chris69's Avatar
Chris69
i've currently got 15/50 mobil 1 in mine and its smoother than its ever been.
i was using castrol magnatec 10w40 before that and it seemed fine but not as smooth
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
YODI
Aug 30, 2015 01:12 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
yawiejon
15
Aug 9, 2015 06:36 PM
