2 wheel drive compresion
Old Dec 3, 2006 | 09:21 AM
shogan3's Avatar
shogan3
Default 2 wheel drive compresion
can any one help me do any of you no the psi compresion on a standard engine ive just checked mine
no 1 140psi
no 2 140psi
no 3 137psi
no 4 140psi
im thinking the car has low copresion pistons as the engine had new pistons aprox 3 years ago but the invoice only says surply 4 pistons on it at 460 pounds and this was done by owner before i got the car
the car is running 376 bhp greys rs500 torring car head from cosworth group a airfilter/dump valve at well lane turbo center with a t3 turbo running 27psi but about to fit a t34 to the car
thank you for your help
Old Dec 4, 2006 | 06:03 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Im not sure if the compression says its low or not mate, i dont no if a compression test tells you that or not, some of the other fella`s will no better
What i can say is i find it very hard to believe that your car has 376 with a t3, not a dig or anything but people struggle to get that with t34`s
FlashRS
Sep 14, 2015 12:36 PM
adam151082
Aug 30, 2015 08:34 AM
borboyous
Aug 22, 2015 11:17 AM
cossynut2
Aug 19, 2015 11:29 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
