blown head gasket, how hard to change it
Old Dec 2, 2006 | 10:20 PM
Twellsie's Avatar
Twellsie
Default blown head gasket, how hard to change it
as above, i am not a mechanic but have a reasonable understanding of how things go together, it has also been wire rung, is this a hard job? and how dou you go about dialing in the cams etc?
Old Dec 4, 2006 | 08:48 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
You don't have to touch the cams mate, just make sure its at tdc when you loosen the belt and it's easy.
If you are unsure its worth getting someone with experience to help or do it.
Old Dec 4, 2006 | 11:31 AM
Twellsie's Avatar
Twellsie
cant the cams turn freely once you remove the head and they are under no tension from the belt?
Old Dec 4, 2006 | 01:35 PM
bud-weis's Avatar
bud-weis
Football Cwazy
it's not too difficult to be honest,defo need a friend to help you lift it off etc,and refit it,the cams timing is fairly easy too,just have to make sure all of the pointers are in the right place when the belt is fitted (i have a picture of the correct aligment somewhere which will help.....ill find it asap)
out of interest,where has the gasket failed?
Old Dec 5, 2006 | 11:37 AM
Twellsie's Avatar
Twellsie
not sure yet mate, havnt taken the head off yet just know that it seems to be loosing water and gaining oil
Old Dec 5, 2006 | 12:38 PM
bud-weis's Avatar
bud-weis
Football Cwazy
does it still run fine? no misfires/smoke etc? is it smokey in the morning (white smoke)?
are there any leaks down the exhaust side of the block,towards the back?
Presumably Karl wire rung it? if so i doubt it has gone around the fire rings
any other symptoms?
Old Dec 6, 2006 | 11:32 AM
Twellsie's Avatar
Twellsie
it does run but it seems very lumpy and smokey as hell, and every time it comes on any kind of boost it shoots oil out the breather,
there doesnt appear to be any visable leaks
yes it was Karl that rung it
Old Dec 6, 2006 | 01:07 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
it dont sound as if the head gasket has gone it sounds more like the valve stem oil seals
is there a lot off water comein out off the exhaust when the car is idlin?
Old Dec 6, 2006 | 07:11 PM
Twellsie's Avatar
Twellsie
there isnt really water comin out but you do get a bit of condensation on the bumper above it
rex647
Mar 6, 2022 06:20 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
