Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Building an RWD mk3/4 escort?
Old Nov 30, 2006 | 05:32 PM
robmarriott's Avatar
robmarriott
Default Building an RWD mk3/4 escort?
sierra floorpan?
I've always fancied a 24v mk3 or 4, so that's what I'll be doing.
I can weld, so that's no problem, just want to know what the best way to tackle it is really.
Old Nov 30, 2006 | 10:14 PM
daveselwood's Avatar
daveselwood
Default rwd mk3,4
a company called gartrec used to build them google it not 100% on the spelling
Old Dec 1, 2006 | 11:23 PM
robmarriott
yeah, but gartrac g3 shells, or genesis shells aren't cheap
Old Dec 2, 2006 | 10:14 AM
djmillsy's Avatar
djmillsy
Fife Radge
im thinking of doing the same you need a sierra to cut the tunnel out and its a lot of work but it would be worth it tho hope you decide to do it
Old Dec 12, 2006 | 09:02 PM
woppy's Avatar
woppy
hi i have a mk 4 with a genesis kit fitted baught it unfinished but drives well now in the process of fitting a pinto turbo engine and cosworth management
Old Dec 25, 2006 | 05:30 PM
rosie's Avatar
rosie
get some pic's up
Old Feb 4, 2007 | 04:31 PM
harry..gti's Avatar
harry..gti
can this be done to a mk6
Old Apr 3, 2007 | 02:48 PM
Avi's Avatar
Avi
I'm sure it can, just no one's bothered yet as far as i know, lots more work.
You can make pretty much anything RWD with enough time and money
Old Apr 3, 2007 | 03:49 PM
djmillsy's Avatar
djmillsy
Fife Radge
welll you get 4wd mk6 escorts so i dont see it being a problem
Old Apr 3, 2007 | 09:46 PM
Benni's Avatar
Benni
Ban[B][/B]ned
When you make a FWD car RWD can you keep the inside totally standard? Benni.
Old Apr 4, 2007 | 04:14 PM
djmillsy's Avatar
djmillsy
Fife Radge
yes moro or lees depends on the car worst case youd need to ft a tunnel
Old Apr 4, 2007 | 04:17 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Cheers mate.
Old Apr 7, 2007 | 04:25 PM
COSSIE CAL's Avatar
COSSIE CAL
difficult job but can be done to most cars,ive even seen suzuki vitaras with a 300bhp yb,you name it,its probly been done,a cossie yb would be easier though.BUy a complete 2wd or 4x4 damaged cosworth for Ł2000 ish,then get a cheap motor i.e a Ł250 1996 manual mk6 escort,then strip both cars,cut out all the parts from saph that you need i.e floor pan etc.make parts like diff hangers etc.and you will need a escort cossie prop(length of escort)2wd diff,t5 gear box if 2wd,yb turbo engine(best engine to use)any more info PM
Old Apr 17, 2007 | 11:00 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
Lloyd
Old Apr 17, 2007 | 11:03 PM
Lloyd's Avatar
Lloyd
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
