dump valves
Old Nov 30, 2006 | 02:21 PM
smitsturbo's Avatar
smitsturbo
Default dump valves
why cant group A dumpvalves go on rs turbo's
with metering units...
dont they work the same as normal dump valves???
Old Nov 30, 2006 | 03:20 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Some dump valves are diaphram based and the vacumn on the induction system stops them from closing completely because of this you always have an air leak and the car idles badly
Old Nov 30, 2006 | 03:40 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
The diapragm ones are no good for the reason above. The bailey type use stroing springs which close off totally and eradicate any idle problems.
Old Nov 30, 2006 | 03:45 PM
SafeChav's Avatar
SafeChav
As said, the diaphram ones open at a lower vacuum pressure and make an air leak which you can't have on an air flow dependant fuelling system.
Even Piston type ones have their effects on MFI although its not always that obvious what its doing to the car!
Old Nov 30, 2006 | 05:33 PM
Oranoco's Avatar
Oranoco
Spend the money on something usefull, why do you want to fit something that does nothing but make your car sound like a bus
Old Nov 30, 2006 | 05:50 PM
daveselwood's Avatar
daveselwood
Default dv
took mine off fed up with the noise ,its something to do with the vacuum
escort ones work on escorts and fiestas,but fiesta ones wont work properly on escorts( baily ones )
Old Nov 30, 2006 | 07:07 PM
smitsturbo's Avatar
smitsturbo
im not fitting no dump valve i was just wondering
Old Nov 30, 2006 | 07:08 PM
SafeChav's Avatar
SafeChav
Whats wrong with buses
Old Nov 30, 2006 | 07:43 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
Que Graceland
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
