cosworth. various parts for sale(updated)
2wd coil, leads, distributor drive, black and silver cam pulleys, water pump, cambelt cover, kidney breather, abs sensors x3, map sensors x1, 2wd throttle postion sensors x1, 2wd and 4x4 actuators x2, black 2wd plenum cover, 2nd hand 2wd clutch from standard car vgc, 2wd alternator, ignition amplifire, rs engraved stainless steel ignition amp bracket, stainless bonnet stay, 2wd oil pump and spraybar, turbo oil feed pipe, various brackets, bolts and sensors etc, big k&n cone from aston martin, cambelt tensioner, thermostat, thermostat housing. probley a few other parts ive forgotten. 07843897663
How much for the distributor (complete) also where in Essex are you bud have family around the area maybe able to collect if the price is right, Also you dont have a 4wd Inlet Plenum Complete if pos ??? (apart from the fuel rail i have one of them)
Thanks Alan
Thanks Alan
Originally Posted by paulpalmer
How much for the ignition leads please? Also do you have a dash 31 actuator? I can't find one anywhere at the moment
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
JK12
33
Apr 26, 2021 12:09 PM
