overheating ?
Old Nov 27, 2006 | 12:58 PM
mitchrst's Avatar
mitchrst
Default overheating ?
whats the best way to flush your radiator ? ever since i bought my rs turbo its had a overheating problem its had 2 radiators as the 1st one burst new thermostat but still the same goes into the red very easy if its not radiator what else could it be ?
Old Nov 27, 2006 | 01:11 PM
antony215's Avatar
antony215
Escort Rs Turbo
Headgasket could be on it's way as far flushing the rad take the pipes off and use a hosepipe to flush it
Old Nov 27, 2006 | 01:30 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Yeah hows the water? and white shit in there?
Fans cutting in alright?
No leaks?
Old Nov 27, 2006 | 09:01 PM
Chris69's Avatar
Chris69
mines averheating at the mo aswell, worse so after a run where i've bin boosting alot.
i've flushed the radiator and fan cuts in etc- sounds like a similiar problem to you
Old Nov 27, 2006 | 09:18 PM
Šhatter Box's Avatar
Šhatter Box
defo headgasket if you done to rads you not got an alloy one on it?
Old Nov 27, 2006 | 09:36 PM
rapidcossie's Avatar
rapidcossie
fucked water pump?
Old Nov 28, 2006 | 03:09 PM
zippyobrien's Avatar
zippyobrien
had this when the header tank developed a small leak,
splits around the seam
Old Nov 28, 2006 | 07:20 PM
mitchrst's Avatar
mitchrst
sorted it was a blocked water pipe that goes behind the head
Old Dec 2, 2006 | 04:07 PM
steven botes's Avatar
steven botes
mate ,get some radiator flush and pour it in
drive 100km and remove the top and bottom rad hoses
shove a hose into the top with a cloth around it and flush
stop when the water turns clear
sorted
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
