Comma engine flushing oil
Old Nov 26, 2006 | 10:04 PM
Toe Knee's Avatar
Toe Knee
Default Comma engine flushing oil
Is this ok to use in a cossie?!?!
was told by a mate there was a post ages ago saying NOT to use the engine flush's u get in the small tins as they can damage the turbo bearing or something as they contain thinner type stuff?!
But comma do 1 that u drain the oil out, then fill it to half the capacity with the flushing oil run it then drain it out and replace the oil.
Wanted 2 check first to be safe and fook anything
Old Nov 26, 2006 | 10:07 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
why would you wanna?
in my experience it makes cars smoke as it removes any gunk and crap that WAS working as a seal somewhere
if your engines bad enough to need it, its so bad the stuff usually makes it seem worse
Old Nov 27, 2006 | 01:28 PM
phil4x4saph's Avatar
phil4x4saph
The idea is that you dont drive with engine flush in.
I dont see that it would do any damage at idle.
Personally I wouldnt bother unless you have contamination problems.
Old Nov 27, 2006 | 01:53 PM
Alvyn's Avatar
Alvyn
have used flushing stuff before BUT DO NOT DRIVE WITH IT IN only use it on tick over and then drain out after about 10 mins then refill with proper oil and new oil filter!
Tony I have done it loads of times without any problems!
Old Nov 27, 2006 | 02:19 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Same here.
Old Nov 28, 2006 | 12:31 PM
fjk404's Avatar
fjk404
Reminds me of a certain silver mk2 escort that someone put engine flush in then drove it about........ lets just say he wish he hadnt.
Old Nov 28, 2006 | 02:16 PM
Bullett's Avatar
Bullett
i sell the stuff and dont suggest any turbo'd car has it.if you want to flush it empty your oil out and put a cheapish normal oil in drive it for a little while then dump it again and put the good stuff in.
Old Nov 28, 2006 | 02:17 PM
Dont bother, just change your oil reguarly.
Old Nov 28, 2006 | 02:22 PM
Bullett's Avatar
Bullett
exactly.mines done every 3k without fail and gets 5w30 synthetic like they did out of the factory.mines still going strong.
Old Nov 28, 2006 | 02:42 PM
5w30 is a bit thin for them once they start to wear IMHO
3000 is a good milage to change on though, plus after every trackday etc if thats your thing.
Old Nov 28, 2006 | 02:55 PM
Bullett's Avatar
Bullett
its got 148k on it,original engine.but it doesnt use much at all.
i dont do track,frightened i'll blow it up or stack it.
Old Nov 28, 2006 | 03:51 PM
Alvyn's Avatar
Alvyn
remember it oh so well ruined a very quick/powerful Pinto engine !
how you doing still at the Abbey?
Old Nov 28, 2006 | 09:56 PM
Toe Knee's Avatar
Toe Knee
Reason i asked is it looks like the engine i bought off some1 has a fooked HG as the oils gone all nice and baileys looking flushed it out with cheap oil twice and put some more cheap oil in just to run it and it was still slightly coloured, so wanted 2 run some flush thru it to clean it before i change the HG and put fresh oil in again.
Wouldnt normally bother using it would just change the oil every 3k odd miles as it usually comes out clean
Althou knowing my luck the fucked oil has prob done the shells, havn't driven it but the car was started and moved about.............
Old Nov 28, 2006 | 11:59 PM
fjk404's Avatar
fjk404
Before anybody gets the wrong idea it wasnt Alvyn who did it , just a mutual friend.
RUBY123
Oct 22, 2023 12:04 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
