Hot Starting Problem & Misfire
Old Nov 26, 2006 | 08:37 PM
dave_y's Avatar
dave_y
Default Hot Starting Problem & Misfire
my car hasn't been driven for about 2 months. i drove it to portsmouth the other day and it has developed a starting problem when hot.
when i started it, it sounded like it was firing on 3 cylinders and it idled at around 500rpm. when revved it was backfiring and generally sounded sh*t i had to keep starting it until it fired up properley and idled at 1000rpm and was smooth.
then after getting it started properly, it developed a misfire on full throttle. at one point flat out in third, it was as if it hit a rev limiter @ 4000rpm and all i got was popping from the exhaust and it wouldn't go any faster
any ideas?
Old Nov 27, 2006 | 12:39 PM
dave_y's Avatar
dave_y
nobody loves me
Old Nov 27, 2006 | 08:23 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
i don't love you either
The hot starting prob on mine was caused by a bad earth. replaced the cable from battery to starter, still available from ford. Problem solved but minus love!!! LOL
Old Nov 27, 2006 | 09:41 PM
fast_ford_uk's Avatar
fast_ford_uk
sounds like the timing may be out, if you had a plug or lead gone down it would miss but shouldnt bang
Old Nov 28, 2006 | 09:37 AM
ivorbiggun's Avatar
ivorbiggun
Could be the 'perenial'.....large plug on rear of ECU. Disconnect it and clean the pins up with a little fine grade wet and dry. I've had this happen on 3 of mine over the years. Car sounds like it's got anti lag (without the power obviously) one min then after doing the above it's perfect. Good luck
Old Nov 28, 2006 | 10:07 AM
Marc LJX's Avatar
Marc LJX
I had a similar sounding prob recently and it turned out to be the distributor.
Just cruising in traffic at about 40 the car started misfiring badly, first thoughts were that something had gone badly wrong with the timing / valve gear or something. Really sounded rough, like running on 2 pots.
After a load of timing checks and head scratching it ended up being the 3 pin pick up plug socket on top of the dizzy. It had become loose and the wires were bare and frayed inside.
New dizzy and away it went
Old Nov 28, 2006 | 04:43 PM
dave_y's Avatar
dave_y
yeah it sounded like a subaru impreza, and had no power, and we can't have that!
also the engine got really hot, that the manifold started glowing!
i will address those issues at the weekend,
the thing is i wanna convert to EFI which would rule out all of these problems
i know you guys loved me really
j.hammond1
30
Oct 31, 2021 05:28 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
taylora1409
Aug 12, 2015 12:06 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
