what could be causing this???
Old Nov 25, 2006 | 06:42 PM
Alvyn's Avatar
Alvyn
Default what could be causing this???
m8 cossie is running 2bar of boost and 470bhp NOW the problem being while accellorating between 3500-4100 revs you can hear what seems to be turbo stall/chattered does go if you plant the pedal though!
Is running T4 turbo and a Bailey d/v with cone filter!
Old Nov 25, 2006 | 06:53 PM
Rs1's Avatar
Rs1
Sounds a bit like surge............basicly the engine can't consume the air the turbo is supplying..............i'll not try to explain,best of reading Stu's write ups
Old Nov 26, 2006 | 12:58 PM
xr-stu's Avatar
xr-stu
yeah 2nd that, surge.
Old Nov 26, 2006 | 02:08 PM
Alvyn's Avatar
Alvyn
thanks for replies so what's the repair? I'll do a search also
Old Nov 26, 2006 | 02:27 PM
GARETH T's Avatar
GARETH T
sometimes a bit of mapping can get around it,,, but it really needs to change the engine spec
Old Nov 26, 2006 | 02:31 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Again.. sounds like surge
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
rsturbo27
Sep 5, 2015 05:08 PM
