EFi Conversion?? HELP!
Old Nov 25, 2006 | 03:44 PM
S2 turbo's Avatar
S2 turbo
Default EFi Conversion?? HELP!
Ive been trying to convert my S2 to efi for a while now but i just cant get thye car to run right it's got a Mk4 cab efi loom, ofab chipped ecu,3 bar map sensor,escort cossie fuel pump,biege injectors, but the car runs at idle fine but just wont rev up at all it just cuts out? so i swapped two wires to the map sensor now the car revs with a bit of a miss but wont tick over can anybody help??
Old Nov 25, 2006 | 04:14 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
fit a FRST loom.
Old Nov 25, 2006 | 04:43 PM
xr4x4rs's Avatar
xr4x4rs
weell
with te escort efi loom you may have to change the pins on the ecu to match a frst
does your chip allow the use of a 3bar map sensor?
did you wire the supressor in the loom for the map sensor for the ofab
i was told this is needed
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
