HELP!! How do i remove my item from Ebay?
Have listed an item on eba and my buy it now has disapeared? How do i add the buy it now back if possible or failing that, remove the item from auction
cheers gys
quick response needed
cheers gys
The buy iy now bit has gone because you need'nt set a resive i also found this out the hard way
Get a m8 to bid
Then just swop feed back and put it down to exprience (sp)
Get a m8 to bid
cheers gys
cheers gys
BUY IT now price WILL be removed as soon as someone bids on the item
as said above regarding removing your item go into the services pages!
