Starting car after 3 months
Old Nov 24, 2006 | 11:10 AM
PT's Avatar
PT
Default Starting car after 3 months
I am starting my car on Sat and it hasnt moved from its carcoon since I got back from Ford Fair, are their any checks to do to be on the safe side.
Old Nov 24, 2006 | 12:08 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Disconnect fuel injectors and crank over for 30s first, to build up oil pressure. Reconnect injectors and fire up. The top end will likely sound noisey for a few minutes, as all the oil will have drained out of lifters etc.
Old Nov 24, 2006 | 12:45 PM
PT's Avatar
PT
great stuff thanks alot mike
Old Nov 24, 2006 | 03:51 PM
Escort.Cosworth's Avatar
Escort.Cosworth
As mike said and maybe worth a check on the oil and water level aswell
Old Nov 25, 2006 | 01:15 PM
AJC's Avatar
AJC
will just disconnecting coil flood it?
Old Nov 25, 2006 | 04:13 PM
ESCYSCOTT's Avatar
ESCYSCOTT
yes
Old Nov 25, 2006 | 09:56 PM
Aaroncast's Avatar
Aaroncast
hi, after a bit of a lay- up drop some oil in the rocker cover prior to starting up
((gives the top end a lube on initial start )think new cams!! those few moment make all the difference when bringing oil up from the sump!!!!!!!!!!!-guru7001/2
Old Nov 26, 2006 | 06:39 PM
Dave Parker's Avatar
Dave Parker
sure ive read somewhere that yb heads have a non oil return valve in the head to prevent dry running from cold?
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
track.focus'd
Aug 12, 2015 05:53 PM
Adam-M
22
Aug 10, 2015 10:46 AM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
