oil separator
no it has not go a tiny 1 it has got 4 outlets on it they are 2 at the top 1 just below them and 1 at the bottom, the 1 that gots to the atmoshepre do i connect that to the metering unit
i have the same type of seperator and followed step by step instruction in performance ford and one of the hoses went into the metering unit...but for some strange reason car won't bloody start but not to concerened at the moment as the car is going through a bit of a resto..but i would also apreciate any info on this subject
Originally Posted by michaelward
i have been told by spec-r to connect the bottom outlet to the metering unit does any1 no if that is right thanks
no its wrong its as rick said above, its the top right one that you can connect to the metering unit but its better if you dont as the oil vapor will contaminate the metering unit and make it run like shit
deathrider666
Sep 28, 2015 06:12 PM
