cossie water pump
Old Nov 22, 2006 | 08:09 PM
turbo1973's Avatar
turbo1973
Default cossie water pump
how easy or hard is it to fit a water pump to a 2wd cosworth
Old Nov 22, 2006 | 08:40 PM
MICKY84's Avatar
MICKY84
Default COSSIE WATER PUMP
QUITE EASY IF YOU HAVE BASIC TOOLS AND UNDERSTANDING OF CARS. GET A HAYNES MANUAL IT WILL SHOW YOU. SHOULD ONLY TAKE HOUR TOPS! SLACKEN BOLTS ON PULLEY ON WATER PUMP 1ST BEFORE SLACKENING FAN BELT AS ONCE PULLEY MOVES FREELY YOU WONT BE ABLE TO UNDO THEM. MAKE SURE YOU BLEED COOLING SYSTEM PROPERLY AFTER ASWELL OR RISK OF AIR LOCK AND OVERHEATING.
HOPE THIS HELPS
155lee
Oct 27, 2015 04:55 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
