engine front crankshaft oil seal housing help!!!!
From: learnin to build a yb lump properly in dennis's garage
mine is stuck onto the crank,does anyone know where i can get a replacement??? no longer serviced by fords
if the engine's out of the car and you're removing the crank anyway, then :
1. take out the crank complete with the pulley and front cover,
2. get a B+D workmate and open it up so that the crank can pass through the gap between the jaws
3. support the crank vertically so the front cover takes the weight on the workmate
4. put the pulley bolt loosely in the end of the crank and smack it with a deadblow - get ready to catch the crank as it falls off the previously stuck pulley
this way, you've got a good chance of not damaging the front housing
works for me
works for me
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
st220kyle
16
Aug 14, 2015 06:13 AM
Gadget
Aug 13, 2015 08:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
