Info about group A Fuel pumps - PIXTURE ADDED
Hi guys
So I have now bought a group A fuel pump from TF, and now I need to get a fitting kit. One small question.
I notice on the ads for the compelte pumps and fitting kits that in the photo there is a long bit that screws into the pump between the two terminals. Mine has not got this bit on it. Is this part of the fitting kit, or the old pump, or is this a different bit again
Thanks guys
JJ
Thanks guys
JJ
I think the bit you mean is the non return valve, which will be attatched to the old pump, I don't think they're supplied with a new pump or with a fitting kit.
This stops fuel returning into the fuel tank via the pump when it isn't running, so there is instant fuel in the system (lines, rail) when you start the engine.
the bit you need is for the inlet end of the pump.... a sierra cosworth pump has a push on hose fitting but the gpa pump has a threaded end so you will need an adaptor fitting.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
The adaptor to fit in the pump suction looks like this
Available from
http://cgi.ebay.co.uk/Cosworth-044-G...QQcmdZViewItem
Available from
........... or just aeroquip it and do it properly
JJ
Available from
Available from
Cheers matey!!
I have ordered one until I can sort the aeroquip stuff!JJ
Originally Posted by Bosch-Man
My pumps come with the non return valve...its the inlet end that dont come with it..as shown above.
JJ
You need the non return valve YES...cant think why you aint got it....i guess if you take the one off your std pump it will fit.
I guess this is the price of buying nearly new, rather than totally new!
JJ
JJ
kosienutter
31
Aug 22, 2015 09:55 AM
just to make sure that this is not a bit i will need to hunt down, and is on my current pump (non gp a)
