rebuilding a zetec block for turbo project. whats needed
just putting together a list of parts im going to need.
so far i got:
rings for the let pistons
shells
sump gasket
new bolts for the u shaped things that hold the crank on. (i know that must sound stupid to everyone but i cant remember what they are called)
what oil seals and gaskets will i need?
so far i got:
shells
sump gasket
-1.8 sump
-1.8 oil pump
-1.8 water pump
(and all associated gaskets)
-Focus metal headgasket
-cam cover gasket
And a LOAD more things
Give me a ring when you get to that stage
-1.8 oil pump
-1.8 water pump
-cam cover gasket
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
Zoggon
Aug 10, 2015 10:39 AM
