How Hard Would It Be...........
Old Nov 20, 2006 | 04:36 PM
Phil DJ's Avatar
Phil DJ
Default How Hard Would It Be...........
To put a Mondeo 2 litre lump into an XR2i which has had a CVH in it all of it's life?
What would I need to swap over, what would I need to buy?
Would I need a Cat for the MOT?
I know this sort of thing has been done before but from what I can gather it has been done with the 1800 zetec models?
Any help much appreciated
Old Nov 20, 2006 | 06:00 PM
Oranoco's Avatar
Oranoco
You will need the engine loom and ECU for the 2.0 as well as the correct engine mounts. Not sure but you may find the radiator is different between the CVH and Zetec cars
You won't need a CAT for the MOT.
Old Nov 20, 2006 | 06:21 PM
Phil DJ's Avatar
Phil DJ
That's great. I've basically got a complete Mondeo to get the engine and parts off anyway.
Would the engine mounts line up with the mounting points?
Old Nov 20, 2006 | 06:55 PM
Oranoco's Avatar
Oranoco
Not sure to be honest mate did it when he went Zetec turbo on his FRST so I'll ask him when I see him next
Old Nov 20, 2006 | 07:50 PM
Wardy257's Avatar
Wardy257
You will need to use a 1.8 ZETEC waterpump too.
Old Nov 20, 2006 | 09:29 PM
Phil DJ's Avatar
Phil DJ
Will the 2.0 waterpump not fit then?
Cheers mate
Old Nov 26, 2006 | 05:39 PM
Phil DJ's Avatar
Phil DJ
Ok, change of plan. The engine I've got isn't that great after all. Plus can't be arsed
Ok, another question, what would I need to turbo it?
Other than:
Turbo + Manifold
ECU
Old Nov 28, 2006 | 05:28 PM
Phil DJ's Avatar
Phil DJ
Anyone?
Old Nov 28, 2006 | 05:41 PM
Oranoco's Avatar
Oranoco
All the elctrics although your loom can be modded to work with a couple of pin swaps iirc.
Fuel pump, tank injectors, head and cam are all the same as the FRST items. You will need to change the cam pulley as the FRST item is slightly more retarded.
You'll need the bottom end, rad, fan, intercooler, exhaust, turbo etc. While you've got it in bits you might as well T3 it as the T2 is a big bucket of arse and not capable of anything to write home about.
Old Nov 28, 2006 | 06:31 PM
Phil DJ's Avatar
Phil DJ
Wicked, thanx for that
sridgett
Oct 1, 2015 07:30 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
