400bhp is not that much to ask, whats stopping it.
Old Nov 20, 2006 | 12:57 PM
leecavturbo's Avatar
leecavturbo
Default 400bhp is not that much to ask, whats stopping it.
2.5" exhaust ? surely that will do ?
252deg duration cams?
GT2540R .86 hotside full boost 4k.
7.9:1 C/r
no AFR problems
no det problems.
mechanically sound engine
mapped
Old Nov 20, 2006 | 12:59 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
What boost?
Whos mapping it?
Old Nov 20, 2006 | 01:00 PM
xr2i-carl's Avatar
xr2i-carl
on stadard internals and head dimensions?
Old Nov 20, 2006 | 01:01 PM
leecavturbo
1.2bar held. no fluctuation. mapper is not the prob.
leecavturbo
well that don't matter but its built to take it.
Old Nov 20, 2006 | 01:06 PM
Stu @ M Developments's Avatar
PassionFords Creator
Your air pump is simply too small if the mapping is ok, so start looking at airflow restrictions...
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
400bhp @ 1.2 bar?
I would have said that's a little too much to expect!
Also, I wouldn't have said that the torque diving like that is anything out of the ordinary.
Does the dyno its on give a boost plot?
Old Nov 20, 2006 | 01:08 PM
Porkie's Avatar
Porkie
1.2 bar?!?! I wouldn't imagine mine makes 400bhp at that and I have a much bigger Turbo! and a better engine
leecavturbo
Originally Posted by Christian and Beccy
400bhp @ 1.2 bar?
no no no, it won't make anymore power above 1.2bar. it does make more boost if we set it to.the boost is virtually at flat line of 1.2bar to redline after 4k
Bit low. What makes you expect such low boost?
Old Nov 20, 2006 | 01:09 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Your never gonna get 400bhp on that turbo at 1.2bar. On that turbo its a 2bar+ job really unless got mega lairly cams etc and a lot of luck.
2.5in exhaust isnt brilliant.
Rest of spec seems ok.
Cam timing?
Porkie's Avatar
Porkie
Head not up to the job of flowing enough air then?
Old Nov 20, 2006 | 01:11 PM
leecavturbo
i don't expect such low boost , that is the level of boost that it stopped making anymore power. i.e @ 1.4bar 1.5bar it did not make more power!
all parameters where optimal , act,egt,timing,afr etc etc
Old Nov 20, 2006 | 01:12 PM
leecavturbo
Cam timing?
NO. i know that! it what i'm saying is it won't make anymore power with more boost ( we tried it )
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I think the exhaust needs looking at as well! Measure the back pressure, I bet it's the same as the boost pressure .
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Then surely it has to do with the flow of air and how much the engine can or cant comsume. I'd say head work or cams is the problem then
leecavturbo
600bhp proven flown thru this head
Old Nov 20, 2006 | 01:13 PM
leecavturbo
preturbo or after and how far after? 1 inch 1 foot 1 metre ?
Old Nov 20, 2006 | 01:14 PM
Porkie's Avatar
Porkie
Exhaust then...
Or are you SURE the cams are correct and timed right? Its not unheard of to get wrongly ground cams even brand new.
Old Nov 20, 2006 | 01:15 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
But backpressure can be 3times boost pressure and still be making good power.
Its not an ideal situation, but be suprised if a 2.5in is holding him back THAT much.
How far away from 400bhp are you now? Still at 336bhp yeah?
Ok, maybe it is the exhaust, didnt realise youd got that high already.
Old Nov 20, 2006 | 01:16 PM
CossieRich's Avatar
CossieRich
If head has been proven to flow the corect volume of air for 600 bhp, then that surely only leaves the cam choice and cam setup or as Mike R has suggested, exhaust back pressure and therefore heat
ECU Monitor Enthusiast
leecavturbo
315bhp! it made 336bhp with higher C/r on the same exhaust,head,turbo etc etc
Old Nov 20, 2006 | 01:17 PM
leecavturbo
Originally Posted by SECS
Ita a vauxhall - Nuff said
well thats very helpful however there is as much aftermarket stuff in this engine/setup as most of you use/rate/want !
Old Nov 20, 2006 | 01:24 PM
Porkie's Avatar
Porkie
You tried asking Chip? could be your man
Old Nov 20, 2006 | 01:39 PM
GARETH T's Avatar
GARETH T
has the baffle fallen appar in the exhaust?
Old Nov 20, 2006 | 01:43 PM
As i mentioned on vauxsport mate, it would be good to see the fuelling and timing maps.
IF its failing to flow the air anymore, it should be very obvious from a big drop in injector duty per cycle.
It certainly seems like a flow issue though of some sort, have you tried measuring the boost pressure just after the turbo and at the manifold and seeing what sort of drop you get through your IC and pipework etc?
Old Nov 20, 2006 | 02:01 PM
leecavturbo
might run it with the exhaust off at the cat replacement?
be noisy but atleast i can rule that out for undoing 3 bolts and a quick power run?
Old Nov 20, 2006 | 02:03 PM
leecavturbo
goes to download maps, bugger could of pulled off the data log after the power run
Old Nov 20, 2006 | 02:05 PM
worth a go lee
Old Nov 20, 2006 | 02:13 PM
If lots of extra boost pressure fails to yield any extra power then you have most probably either:
1) Reached the TIP max.
The head cant flow anymore volume due to turbine housing/manifold.
2) Hit a huge flow restriction in teh exhaust.
The turbine cant flow any more volume due to backpressure in exhaust.
P.S: Both the above will normally show unusually high EGT's.
3) Hit a flow restriction in the inlet/head
Not easy to measure in absolute terms on a speed density system. Try measuring TIP and turn teh boost up to see if it raises.
4) You have run off the compressor map and into excessive compressor heating.
Have you measured the Air temps at the inlet when Mapping?
4) Camshaft misstiming is causing a massive drop in VE.
What are teh cams dialled in at? Is it laggier than expected?
One of the above will very likely be your problem.
Old Nov 20, 2006 | 02:45 PM
leecavturbo
fuel.
ign.
compensation
Old Nov 20, 2006 | 02:48 PM
leecavturbo
why is it when i post pics sometimes they look compressed, then when i come back to look sometimes there ok?
Christian and Beccy
#1 in Spelling Club
Also, the turbo, it could be mismatched spec. This is quite common.
For example, we have just changed the exhaust housing on a turbo we were running on something to the next size down and made 30bhp more!
There is alot to turbo-spec'ing and mistakes are often made.
Old Nov 20, 2006 | 02:50 PM
leecavturbo
we'll were all learning just i'm the guinea pig
Old Nov 20, 2006 | 02:51 PM
Indeed, the problem is that the compressor map only shows a portion of the story, it doesnt show the potential for a huge drop in VE due to a hotside thats too small!
Old Nov 20, 2006 | 02:53 PM
leecavturbo
just realised them maps don't mean jack wothout the boost compensation info sorry chaps
now added
Old Nov 20, 2006 | 02:54 PM
leecavturbo
stu its a large hotside!
Old Nov 20, 2006 | 02:57 PM
Lee, the inlet manifold is anothe suspect.
Have you given any thought to replacing it?
Old Nov 20, 2006 | 03:04 PM
leecavturbo
correct my theory if you will. turbo's were essential invented to over come the restriction in the inlet tract/valves etc by forcing air past?
now i'm sure i'm correct by thinking that for more volume past a fixed size hole more pressure is required. hence turbo's. i realise i can run less boost but the same volume of air if the flow hole/tract in increased by size/flow characteristics. but hasn't this manifold already flowed enough volume at under 2 bar to give 400bhp over in sweden etc ?
