Wirng question
Old Nov 20, 2006 | 10:03 AM
Rippers's Avatar
Rippers
Monte Geek
Default Wirng question
When my autoelectrician unravelled the wiring loom that runs along the bulk head.. by the alloy brake distributer block on the left hand side under battery there was a single wire (brown with red stripe) with a black connector on it with a male spade. Can't see what it would plug into and its quite short so doesn't reach much.. diagnostic port? or something else?
Old Nov 20, 2006 | 04:17 PM
dave cos4x4's Avatar
dave cos4x4
do the escort cosworths have the ford alarm horn in the battery tray bit like other escorts....
it may be off that horn.
Old Nov 20, 2006 | 06:30 PM
The DIVA's Avatar
The DIVA
Mine has one,it goes inside the car through the bulkhead bung and plugs into a cable under the glovebox....
Don`t know what it`s for yet though...
Old Nov 20, 2006 | 09:12 PM
Ryan's Avatar
Ryan
oil pressure for centre console gauge.
Old Nov 20, 2006 | 10:22 PM
Rippers's Avatar
Rippers
Monte Geek
Old Nov 23, 2006 | 02:58 PM
Damo V's Avatar
Damo V
not for centre console guage, mine was as nightdavva said, inside the car, its for some sort of switched earth as its the same type/colour as the a pillar door pin switches..
Old Nov 23, 2006 | 03:02 PM
Rippers's Avatar
Rippers
Monte Geek
Well everything works so I'm just going to wrap it back up into the loom
EDIT quite thought is there a light or any type of switch in the glove box?
Old Nov 23, 2006 | 03:08 PM
Dave Henshall's Avatar
Dave Henshall
Originally Posted by Paul Ripley
same as mine
no idea what its for thogh...
Old Nov 23, 2006 | 05:47 PM
Dave Henshall
lookin at the pic again..... the other end (which i though that was) is near the fuse box, when you dro it down its there - but for no apparent purpose- just taped to the loom ..?..?
Old Nov 23, 2006 | 05:51 PM
Rippers's Avatar
Rippers
Monte Geek
Could it be anything Water injection related?
Old Nov 24, 2006 | 08:58 AM
Dave Henshall
maybe...? or a spare wire thats from the normal escort loom cary-over..?
or maybe somthing for the Air con, as it goes near the intake for the blower - maybe to switch from fresh air to recirc..?
Old Nov 24, 2006 | 09:04 AM
Rippers's Avatar
Rippers
Monte Geek
Well its another cossie mystery
Old Nov 24, 2006 | 04:31 PM
THE RADMAN's Avatar
THE RADMAN
deffo not to do with aircon
Old Nov 26, 2006 | 09:06 PM
Jake_N's Avatar
Jake_N
Could be wire for aircon cut off when in full throttle ? just a guess
Old Nov 27, 2006 | 06:23 PM
Damo V's Avatar
Damo V
Its not linked to the engine management in any way mate....
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
