SPARK PLUG GAP FOR STAGE 3 4X4 COSSIE
Old Nov 19, 2006 | 10:16 PM
COSWORTHJOE's Avatar
COSWORTHJOE
Live in the fast lane
Default SPARK PLUG GAP FOR STAGE 3 4X4 COSSIE
can anyone help with this problem car has misfire when on boost at around 12 psi fine below this. all new parts leads arm dizzy cap gpa coil and phase sensor set to correct gapping and running pp8 plugs on standard gap what should this gap be?
Old Nov 19, 2006 | 10:18 PM
SPADGE's Avatar
SPADGE
Hi
Around 0.65mm or a little bigger if you can get away with it.
Old Nov 19, 2006 | 10:20 PM
KSA-Cossie's Avatar
KSA-Cossie
0.65 and use 071 plugs.
Old Nov 19, 2006 | 10:37 PM
COSWORTHJOE
thanks mate i'l give that a try
Old Nov 19, 2006 | 10:42 PM
radiant red's Avatar
radiant red
well im on .5mm with 34 psi but you should be able to go higher as already stated
Old Nov 19, 2006 | 11:04 PM
COSWORTHJOE
are these plugs motorcraft or what make mate?
Old Nov 19, 2006 | 11:07 PM
radiant red
sorry pal,im running c59's and she doesnt miss a beat idles a little lumpy but it has an uprated cam so to be expected i guess.anything more than .5mm its misses at around 20 psi
Old Nov 19, 2006 | 11:08 PM
radiant red
welcome to pf btw mate
Old Nov 19, 2006 | 11:12 PM
COSWORTHJOE
thanks mate so there champion plugs need to get a set soon or would i be able to regap pp8 what do you think?
Old Nov 19, 2006 | 11:15 PM
radiant red
yeah you can gap any plug as long as you have feelers,i only use these plugs cos of my big boost there not the best plugs for day to day as they are racing plugs,regap them to .6 and see how it goes mate as long as they are good condition and rest of system is ok then you shoukd be fine at that
Old Nov 19, 2006 | 11:18 PM
COSWORTHJOE
COSWORTHJOE
Old Nov 19, 2006 | 11:20 PM
COSWORTHJOE
****edited by webteam to get link working****
Old Nov 19, 2006 | 11:23 PM
radiant red
tidy looking engine bay looks like its been looked after
Old Nov 19, 2006 | 11:25 PM
COSWORTHJOE
the is a f reg and was rebuilt in 97 and converted to 4x4 so its mega clean all round loads of paperwork for it
cheers mate
j.hammond1
30
Oct 31, 2021 05:28 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Zoggon
Aug 10, 2015 10:39 AM
adriansaleem
Aug 1, 2015 09:28 PM
