Cleaning under Escos boot rubbers and trim etc
Old Nov 19, 2006 | 01:06 PM
MATCOS's Avatar
MATCOS
Default Cleaning under Escos boot rubbers and trim etc
I am doing the Escos boot today and wondered if you have to take off the boot rubber seal and clean under it, I am reluctant to do this as it has obviously never been off and is stuck down very well, I have cleaned round it but not under it-do the judges pull up trim even if it is very well stuck down?
Also should you strip waxoyl from inside any cavities they might be able to reach inside -eg inside bottom boot latch hole -again would prefer to leave it in there as it's there for a reason
Old Nov 19, 2006 | 04:24 PM
M.A.D.RST's Avatar
M.A.D.RST
I know they want to see the tool box and also lift the carpet up to see how clean the floor is and to see if you still have the original spare
Mat, your going crazy
Old Nov 19, 2006 | 06:30 PM
MATCOS's Avatar
MATCOS
What do they want to see the tool box itself or concours tools inside - do you know Nick
And yes I think I am going crazy
I am enjoying it though-have you seen this weekends update
Old Nov 19, 2006 | 09:32 PM
ESCYSCOTT's Avatar
ESCYSCOTT
Hi mate,
I judge at quite a few RSOC concours events and I have shown my car in modified cosworth also. My advice for what its worth..........
Judges will not/ SHOULD not peel back any fixed rubber seals around the boot. Clean it to within an inch of its life in every nook and cranny than can be seen. Once its properly clean and dry, go over it with a dry white cloth and if any dirt comes off onto the cloth, keep cleaning.
Waxoyl inside the lock area, REMOVE IT. Get as far inside as you can with your fingers as judges will judge areas like this with their fingers. This is applicable to the holes on the underside of the bonnet also.
No matter how clean you think your getting the car it can always be cleaner. Get the interior proffesionally valeted, remove the seats before they come so they can get the carpets mint.
Take out you tool kit, re plate or repaint the towing eye gold if it has been used and is scratched and clean up the jack and give it a quick overspray of satin black paint, it'll look good as new
Any more questions, just ask mate
Old Nov 19, 2006 | 09:40 PM
MATCOS's Avatar
MATCOS
Originally Posted by ESCYSCOTT
Hi mate,
Thanks Scott, good advice there- thanks for the offer of answering my questions too
Old Nov 21, 2006 | 08:08 PM
James_RScos's Avatar
James_RScos
Some really great advice in this post taking note from the masters
Old Nov 21, 2006 | 10:39 PM
ESCYSCOTT's Avatar
ESCYSCOTT
no problemo guys
mk1turboestate
Dec 2, 2015 08:31 PM
155lee
Oct 27, 2015 04:55 AM
The Enigma
Sep 12, 2015 10:12 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
