Water leaks - help!
Old Nov 19, 2006 | 12:03 AM
phil4x4saph's Avatar
phil4x4saph
Default Water leaks - help!
My drivers side footwell keeps filling up with water!
Its a '92 saph.
Ive checked the sunroof drainage holes and the windscreen scuttle is all clear, no leaves or crap in there.
I'm fast running out of ideas. Anyone had this, or cured this, or have any idea where I should look next?
Thank you in advance!!
Old Nov 19, 2006 | 04:19 AM
3DOOR ARY's Avatar
3DOOR ARY
try pouring some water around the battery tray.
my old rst had this problem.
Ary
Old Nov 19, 2006 | 03:55 PM
phil4x4saph
I'll check for that - cheers.
Anyone else?
Old Nov 19, 2006 | 03:59 PM
320 bhp's Avatar
320 bhp
its not the heater matrix is it???
Daveesaunders's Avatar
Daveesaunders
Mine did the same thing, the water was getting through the gromitt for the ABS loom and the engine loom which is located directly under the battery tray. I put some sealent round the gromitts and made up a plastic deflector type thing that keeps the water away from them.
Old Nov 19, 2006 | 04:08 PM
BILLY's Avatar
BILLY
My 2wd saff did this on passenger side and turned out to be heater matrix as mentioned before.
Old Nov 19, 2006 | 10:34 PM
phil4x4saph
Its not the matrix - Im getting used to spotting that (my last 2 cars have done that - bloody peugeots! )
I'm sure its rain water,
I'll check the grommits.
Thanks guys!
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
