Problem plz help!
Old Nov 18, 2006 | 12:19 AM
Geogr's Avatar
Geogr
Default Problem plz help!
Hello mates!
I had a problem with my RS under full throttle sometimes i heard something like misses and the car don't accelerate and goes to safe mode.
I had it when i put the Bluefin but yesterday i put it out just to try and again the same problem apears
Anyone knows what i have to do?
I have check all the liquids (steering,intecooler,radiator,brakes) and it's ok.
On my RS i have Bluefin, Milltek De-Cat, Milltek Cat-Back, K&N Gen2,Forge DV006, Standar Plugs and Plug Leads.
Thanks a lot!
Old Nov 22, 2006 | 06:37 PM
Tobester's Avatar
Tobester
Was it fine before your last mod? If yes, then that's the place to start. Sounds a bit like it might be the MAF, but it's hard to tell unless you can tell us when this started happening and what you had just done to it. Bluefin is pretty good and will overcome most small changes in engine parameters but yours sounds a tad more major (but don't panic!) More info please!
Old Nov 23, 2006 | 09:42 PM
rssteve's Avatar
rssteve
Does this occur after 5k? common problem if it does the standard solenoid does not hold the boost so it fluctuates, only way to solve is fit a bleed value or get your self a boost controller.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
