drop off 5.1 gear
Old Nov 16, 2006 | 07:42 PM
Mark_1's Avatar
Mark_1
Default drop off 5.1 gear
Ok so im trying to make sense of these tranny terms.
Say you have a drop off 5.1 rear and 3.62 front on a 4x4 transmission.
Is that to say that you need a 5.1 cwp on the back and 3.62 on the front?
if so... how do you then calculate the speed? what is the final drive ratio?
5.1 or 3.62?
Old Nov 16, 2006 | 08:37 PM
msport's Avatar
msport
yes correct 5.1 rear 3.62 front, You will calculate as the rear 5.1, front is geared with the dropoff to 5.1 even if the cwp is 3.62
Old Nov 16, 2006 | 09:23 PM
Mark_1's Avatar
Mark_1
ok thanks mate.
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
Marv888
Sep 26, 2015 03:44 PM
