breather problem
i was wondering if anyone can help with a simple breathing problem. Both me and my mate have similar specked escort turbos running around 190 bhp but his stales when you take the oil filler cap of but mine doesn't and was wondering which one is correct and what the causes of the bad'n are
The one that 'Runs' may be set-up to do so [basically the return hose for the breather to the metering unit is blocked off and the idle mixture adjusted to suit]. In which case it won't be doing any damage and is a better breather system.
This is how I ran my RST's and collected the oil/fumes in a catch tank rather than returning them to the engine.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
