help - bonnet wont open!
Old Nov 16, 2006 | 01:50 PM
Vic's Avatar
Vic
Default help - bonnet wont open!
after taking my car to a 'braking specialist' yesterday, i have discovered that the damn bonnet wont open and the bonnet release under the steering column has lost tension and cable seems loose.
I have taken out the front grille to reach under the front sill but for the life of me cannot open the bonnet. I tried pulling the cable from under the column to no avail. I think a bracket has broken and therefore has no tension to open the latch.
Apart from using a very large crow bar can anyone help?
Old Nov 16, 2006 | 02:27 PM
ossie cossie's Avatar
ossie cossie
HI VIC I AM IN AUSTRALIA ALSO IS IT AN ESCORT COSWORTH YOU ARE ON ABOUT AS I HAVE ONE AS WELL I WILL LOOK AT IT AND SEE IF I CAN HELP I WILL GET BACK TO YOU
Old Nov 16, 2006 | 08:03 PM
Steve Escos's Avatar
Steve Escos
Have you tried getting some one to push down on the bonnet while you pull the lever. Bizarre but it some times works. Steve
Old Nov 17, 2006 | 10:18 AM
JHS's Avatar
JHS
The wire has probably broken, go to your Ford dealer and order a new wire and plastic lever.
To open your bonnet now, get some pliers and pull the wire underneath your steering column.
Old Nov 17, 2006 | 01:05 PM
Vic's Avatar
Vic
ossie cossie
Hi mate, I have a Sierra Cossie and live in Sydney. Whereabouts are you?
Steve Escos
Thanks for the advice, tried that, and yeah, it has worked before on a previous car of mine. No luck this time.
JHS
Yeah tried that one, and unfortunately didnt work
Good news though. I went to my friendly local mechanic who services dad's car and BINGO!
He got access under the slam panel and with a screwdriver popped the bonnet. Found out the bracket for the cable had popped out and caused a slack cable.
Thanks guys for your help anyways
Old Nov 17, 2006 | 01:07 PM
Vic's Avatar
Vic
ive just realised i've posted in the escort cosworth section.. whoops!
Old Nov 17, 2006 | 01:40 PM
C.Lyon's Avatar
C.Lyon
Undo the 4 bolts from the bonnet catch.
Fix it after
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gingeRS
17
Oct 2, 2015 09:42 AM
