erst Bailey breather on frst?
Old Aug 30, 2004 | 01:34 AM
RScrew69's Avatar
RScrew69
Default erst Bailey breather on frst?
Does anyone know if you can modify or block a pipe or something along those lines and fit a s2 erst Bailey oil breather kit to a fiesta rs turbo??
Only reason i ask is i have come across one, lol
cheeRS in advance guys an gals
Old Aug 30, 2004 | 06:25 AM
Gadget's Avatar
Gadget
Spanner monkey
Just pipe it up as the escort!!
Old Aug 30, 2004 | 09:08 AM
Oranoco's Avatar
Oranoco
I've got a FRST Baily breather I'm selling from the wifes dead 2i. PM me if your interested
Old Aug 30, 2004 | 02:24 PM
RScrew69's Avatar
RScrew69
u have pm oranoco mate
gadge, where does the bottom of the erst oil breather go? on the erst it goes to the botom of the air flow meter??
also if i put it on the fiesta the breather attatch's to a little thin pipe on efi which has air running through it and theres 2 bits where the hoses is plugged into that has air travelling through there just infront of the injectors. Do i blok this off as i can't attatch it to the breather.
cheers
Old Sep 2, 2004 | 07:33 AM
Gadget's Avatar
Gadget
Spanner monkey
Block off the 2 outlets in the manifold, the return goes back down to the sump as the normal pipe on the passenger side standard breather pipe would and actual breather port at the bottom goes to atmosphere! you may have to re drill the bracket where it is held on by the fuel pump blank nuts on the back of the head or just tweak" the bracket like i did!! to clear the fuel pressure regulator!!
Old Sep 2, 2004 | 10:56 AM
RScrew69's Avatar
RScrew69
cheers mate,
where is the actulal breather port? and u say that goes to atmosphere, any pics.
so got it setup like urs at the mo in pic, bottom pipe goes to the bottom end, where black pipe is which joins rocker cover closest to dizzy sid of car, so where is this actaul breather port that vents to atmosphere?
also i got the blanking off of those 2 little pipes on the inlet manifold where the injctors are.
cheers again
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
