rear beam
Old Nov 14, 2006 | 09:21 PM
maxrs16's Avatar
maxrs16
Default rear beam
hello i need a rear beam for a two wheel drive cozzy but is there a beam of a normal sierra that will fit
Old Nov 15, 2006 | 02:35 PM
foreigneRS's Avatar
foreigneRS
Testing the future
no. cossie uses a 7.5 inch diff, normal sierra's use a 7". mounting plates on the beam will be too close.
you can put a 7" diff in a 7.5" beam with spacers, but not the other way around.
hint: rear beam and diff were carry over parts from granada
Old Nov 15, 2006 | 04:15 PM
maxrs16's Avatar
maxrs16
so attack a granny then
Old Nov 15, 2006 | 04:22 PM
PiperDOHC's Avatar
PiperDOHC
Sierra 2.0 glsi's between 90 and 91 had a 7.5inch rear diff and the beam is identical. As far as i know only the glsi's of this age tho, these cars had no abs but rear discs and 2 tone bodywork!
Hope this helps
Old Nov 15, 2006 | 04:28 PM
maxrs16's Avatar
maxrs16
is there any way by looking if a car has a 7 inch or 7 1/2 inch diff
Old Nov 15, 2006 | 04:30 PM
dojj's Avatar
dojj
Resident Wrestling Legend
depending on where you are, i've got a granada 24V rear beam and trailing arms waiting to go to the tip
if you want them they are yours for however much it costs you coming and getting them
i'm in west london btw
Old Nov 15, 2006 | 04:36 PM
maxrs16's Avatar
maxrs16
I'm in Birmingham if i new how to identify the 7 1/2 diff i would go to the scrappy it wouldn't cost much
thanks for the offer though dojj
Old Nov 15, 2006 | 04:37 PM
PiperDOHC's Avatar
PiperDOHC
You can tell what diff it has by the vin no. but apart from that, and what ive said above, no! unless you get out a ruler and measure it!
Im sure dojj knows how to tell from the vin no, i cant remember off hand. There is a program somewhere that you can type in the vin no. and it tell you every detail of the car as it left the factory.
Old Nov 15, 2006 | 04:42 PM
maxrs16's Avatar
maxrs16
so basically measure the mounting points on my diff and then go and measure at the scrappy
Old Nov 15, 2006 | 04:49 PM
PiperDOHC's Avatar
PiperDOHC
Yup! thats the best way!
Dont even bother getting under the car unless it has the dohc 8v 2.0 tho, as these are the only sierra's with a chance of having the correct beam!!
Old Nov 15, 2006 | 05:08 PM
dojj's Avatar
dojj
no worries
most, but not all, dohc sierra's from 90 - 92 have a 7.5 inch rear diff
you will have to swap over your exhaust hanger bracket though from the passenger side rear because they don't have them (should be able to unbolt it and refit)
the measurements you want are to be fond on the top of the diff though, so unles you can reach it's going ot be difficult as the bottoms are the same size
if you do find a beam out the measurement at the top of the diff is 193mm of something, the smaller ones are 177 i think (this is from memory as i can't rememebr where i wrote them down)
Old Nov 15, 2006 | 05:09 PM
dojj's Avatar
dojj
and in my condition i'm not quite able to go out and measure them for you sorry
Old Nov 15, 2006 | 05:38 PM
maxrs16's Avatar
maxrs16
thanks much appreciated
Old Nov 15, 2006 | 10:42 PM
escort mk6's Avatar
escort mk6
if you still need a beam, i have a 2wd one here, and im just off the m6 in coventry, pm me
Old Nov 15, 2006 | 11:06 PM
2001ode's Avatar
2001ode
Originally Posted by dojj
no worries
Hi,
Thats diffentence between 7" and 7,5"
Note the retainer position.
Regards
Claude
Old Nov 21, 2006 | 10:53 AM
wraggy's Avatar
wraggy
Default rear beam
i have asierra cosworth rear beam for sale 40 quid + postage pm me
Old Nov 21, 2006 | 05:16 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
damm i thru a rear beam with arms, hubs, and two big pollys in the skip 3 weeks ago, the beam was fine it was the arms that were twisted
sorry mate
sometimes you get the bear
sometimes the bear gets you
Old Nov 21, 2006 | 06:06 PM
shogan3's Avatar
shogan3
in the ford workshop man it says the rear axal crossmember is off a scorpio
hope this helps
Old Nov 21, 2006 | 09:40 PM
dojj's Avatar
dojj
still got this beam and arms sitting in the garen for osmeone who wants to take them away
they are only going to the tip on sunday so if they are of any use (why do i want rid of them? beause i've already got another 3 in the back garden )
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
