Ford Fiesta Zetec Headlamp Problem
Old Nov 13, 2006 | 09:17 PM
corble's Avatar
corble
Default Ford Fiesta Zetec Headlamp Problem
Hi,
I have a 1998 Ford Fiesta Zetec and noticed yesterday that the left main headlamp was not working. The dipped headlight works as normal, so I presumed the bulb had gone. I bought a new H1 bulb and replaced the old one however it still didn't work. I tested the new bulb in the right headlamp and found that it worked perfectly so there must be a different problem. I've tried swapping the fuses for the right and left main headlamps around and the right headlamp still works fine so I'm stumped about what the problem is! Is it likely it will be the wiring and if so how hard/expensive is this to replace? Sorry I'm a bit of a novice!
Thanks,
Tom
JoeyBoyden
Jan 4, 2024 02:36 PM
Botts
Aug 13, 2015 04:16 PM
turbobill
Aug 1, 2015 08:55 PM
