electrical problem
Old Nov 13, 2006 | 04:44 PM
MattFRST's Avatar
MattFRST
Default electrical problem
hi rite well got back home in the RS park up, lock car with the keyfob- central locking thing, go upstairs quick, go back down to car and unlock it, get in turn key, NOTHING! no ignition lights, so i fone a few people, check power at battery- 12v, check power at starter motor- 12v, i get told to check the box on the back of the ignition barrel, so i get in there check that n on the red and black terminals i get 2volt's! but i can still put hazards n that lot on, so theres power, ive check ALL fuses- fine. the only thing is a dont know anything about the immobiliser.
any help would be much appricated
thanks matt
Old Nov 14, 2006 | 08:37 AM
jayRS's Avatar
jayRS
has the key fob got wet? is any of the inside of the car wet? which could of shorted something?
i had this a while ago on my toad ai606, tried everything, in the end i managed to switch alarm off with the code thing and the key and left it, and it started working again, dunno what score was there, prob damp.
anyhow, whip the fuse box down and check fuses again, pull the green relay out, you will prob find a pin all black and burtn, clean it up and pop it back, that is norm a cause for this sort of things at times.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
