Help Whinning rs1800 gear box/engine
Old Nov 13, 2006 | 10:20 AM
PekaRs1800's Avatar
PekaRs1800
Default Help Whinning rs1800 gear box/engine
Hiya
Ive recently starting hearing this whining noice coming from the engine....seems to whine when going up through the revs (mainly in 1st & 2nd) and when I come off the acc and let the revs drop! Car starts and drives fine and goes through the gears ok.
I know my clutch is getting near replacing so I thought maybe it was the thrust bearing whining but now I’m beginning to think its the gear box
(In general the gearing seems fine apart from the odd clunk into gear which is mainly lazy gear changing?)
I’m going to check gearbox oil later, maybe even change it for something thicker.
Any thoughts on this?
Old Nov 13, 2006 | 09:46 PM
dave green's Avatar
dave green
When going up through the gears. just knock it out of gear if the noise goes its not the box
Dave
Old Nov 14, 2006 | 08:28 AM
PekaRs1800's Avatar
PekaRs1800
Ok cool, never thought of that.
I'll give it a go later although im pretty shore it will still do it
Cheers matey
Old Nov 14, 2006 | 01:10 PM
PekaRs1800's Avatar
PekaRs1800
Just went for a drive and knocked it out of gear and the noise definatly went!
Dave, did you mean to say if the noise goes it IS the box?
Old Nov 15, 2006 | 09:11 AM
PekaRs1800's Avatar
PekaRs1800
Can anyone else shed any light on this?
Old Nov 20, 2006 | 01:18 PM
PekaRs1800's Avatar
PekaRs1800
Anyone
Old Nov 22, 2006 | 02:47 PM
PekaRs1800's Avatar
PekaRs1800
Hello, is there anybody out there
Old Nov 22, 2006 | 04:57 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default hello
my zetec does the same i think it will be the thrust bearing my mr 4 has ran with a whinning for years but i dont no about the rs box tho
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
Brian
Sep 11, 2015 08:06 AM
