Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
XR3i questions... Gearbox...
Old Nov 13, 2006 | 05:36 AM
Tezla82's Avatar
Tezla82
Default XR3i questions... Gearbox...
Hi
My old XR3i (1983) with an 1988 XR3i engine needs a new gearbox.
Now, how much different are the normal 1.6 and XR3i gearbox, if any?
And would the normal 1.6 gearbox fit to my XR3i?
The gearbox is an 1990-1991. I was told...
And a 'stupid' question... My father says that the XR3i engine is only an 1.6 with injection. But I ofcourse disagree, because then it would only be 1.6i, right?
What's the difference in the XR3i and 1.6i fx?
Hope to see some answers!
Good mornin' to you all!
Martin - Denmark
Old Nov 19, 2006 | 05:12 PM
Tezla82's Avatar
Tezla82
Can someone please give me an answer?
Old Nov 19, 2006 | 08:38 PM
tuszi's Avatar
tuszi
as you are saying your xr3i is from 83? am i right? then a never gearbok from 86- won't fit right in as i am told, but it will fit with some modifications of mounting brackets i think. the easiest is to find a xr3i or 1.6i from 80-85 as they will fit right on.
your other question about the different in the engines. hmmm what can i say? the 1.6i from 86- has ke jetronic but the xr3i from 86- has k jetronic. thats the main different. some modifications are maybe bigger nosles or so im not sure realy
Old Nov 20, 2006 | 03:36 PM
Tezla82's Avatar
Tezla82
Oh yes... But the engine was from '88... So a mk4 gearbox should fit in then? even a 1.6i instead of xr3i gearbox
And yes... There must be some other mods, or else it wouldnt be 1.6i and xr3i
Old Nov 20, 2006 | 04:52 PM
tuszi's Avatar
tuszi
i think you misunderstood me a little. the gearbox mounting in the chassi is different from mk3 and 4 i have bean told so you see since you have a mk3 you will need to find a mk3 gearbox for your mk4 engine.
Old Nov 21, 2006 | 05:27 AM
Tezla82's Avatar
Tezla82
Oh, I misunderstood you yes
So a mk3 gearbox i what I need... And the mk3 should fit the mk4 engine with no probs?
Old Nov 21, 2006 | 05:46 AM
tuszi's Avatar
tuszi
yes thats what i am told
Old Nov 21, 2006 | 06:50 AM
Tezla82's Avatar
Tezla82
okay.. great... Thx
Old Nov 21, 2006 | 07:28 PM
RSeb's Avatar
RSeb
an xr3i is basically yes a 1.6 injection, and the gearbox casings are different as you say above but all are ib5 so will fit ur engine with no probs, ur chassis requires a box with a front mount of four holes found on mk3 and 5 escorts, a mk4 escort uses a 'cradle' to support the box and is mounted where the bell housing meets the meat of the box so to say
Old Nov 22, 2006 | 05:32 AM
Tezla82's Avatar
Tezla82
So even a mk5 gearbox would fit?
And no mk4 box, unless some modding?
But a mk3 og mk5 box, and no mk4 box?
Thx for reply!
Old Nov 22, 2006 | 05:52 AM
tuszi's Avatar
tuszi
but then you have to have one from the cvh engine in the mk5 if that fits
Old Nov 22, 2006 | 06:59 AM
Tezla82's Avatar
Tezla82
arh okay...
I think i'll just find a mk3 box
Old Nov 22, 2006 | 03:37 PM
RSeb's Avatar
RSeb
no a zetec uses the ib5 as well
Old Nov 24, 2006 | 07:20 AM
Tezla82's Avatar
Tezla82
Thx for answers!
Prickly_buzz
Dec 7, 2017 09:52 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
