Adaptor plate for my turbo/manifold
Old Nov 12, 2006 | 10:43 PM
Billy_RS's Avatar
Billy_RS
Default Adaptor plate for my turbo/manifold
Anyone know where i can get a adaptor plate which would fit in beetween my exhaust manifold and turbo?
Reason being that i got a big turbo. It will nearly fit, but the compressor housing touches the branch on the very right of the manifold, so i cant make the turbo fit on the connection. (Making sense?)
So what i need is the manifold with a "sanwich plate" on and then the turbo will connect.
If anyone can understand what hell the im going on about, then your help would be mucho appreciatio
Old Nov 12, 2006 | 11:14 PM
Šhatter Box's Avatar
Šhatter Box
looks like you got the wrong turbo if it cant fit right
Old Nov 13, 2006 | 12:11 PM
davidnormanuk's Avatar
davidnormanuk
What about something like this and cut a hole for the wastegate?
http://cgi.ebay.com/ebaymotors/OBX-H...50697231QQrdZ1
Old Nov 13, 2006 | 05:06 PM
Turbo-Beal's Avatar
Turbo-Beal
I think i know what you mean. Will this do it?
http://cgi.ebay.com/ebaymotors/New-M...spagenameZWD1V
If you only need a mm or two this might do it.
http://cgi.ebay.co.uk/Ford-Fiesta-Es...QQcmdZViewItem
Old Nov 13, 2006 | 09:22 PM
Billy_RS's Avatar
Billy_RS
Na mate. Its called being different.
Old Nov 13, 2006 | 09:33 PM
Billy_RS's Avatar
Billy_RS
Top one should do it. Cheers mate
Old Nov 14, 2006 | 06:43 PM
scraggyrst's Avatar
scraggyrst
i'm sure you can get something like that made up over here instead off getting one shipped over just take the manifold and turbo into metal works place and ask if they can make up the plate and get it welded to your manifold
Old Nov 14, 2006 | 06:49 PM
davidnormanuk
People say I'm different but my mum says I'm special.
Old Nov 15, 2006 | 06:04 PM
Billy_RS's Avatar
Billy_RS
Old Nov 15, 2006 | 07:49 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
cant you rotate the compressor housing round? i.e. un-bolt it and turn it?
Old Nov 15, 2006 | 09:49 PM
bez1's Avatar
bez1
i had same problem on mine.i just made one out of 3mm plate.is yours the t4
Old Nov 16, 2006 | 09:07 PM
Billy_RS's Avatar
Billy_RS
I know wot you mean, but i don't really fancy taken the turbo apart.
Old Nov 17, 2006 | 05:56 AM
Maki's Avatar
Maki
One angle of the manifold could be machined by few mm and the same thing could be done to the housing. Those few millimeters there will give you enough clearance in the place where you have a problem
Old Nov 17, 2006 | 04:58 PM
Billy_RS's Avatar
Billy_RS
bobsworth
77
Mar 24, 2016 09:30 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
