Convert 4 to 2 wheel drive sierra cossi.
Old Nov 11, 2006 | 09:21 PM
mustang 390's Avatar
mustang 390
Default Convert 4 to 2 wheel drive sierra cossi.
I just want to temperally convert my 4x4 cossi to 2 wheel drive for a bit of fun and then put back to 4x4. If i just disconect the front prop shaft and plug the hole from the gearbox out put, would this be acceptable ? Has any one tried this.
Old Nov 11, 2006 | 11:04 PM
jon@work's Avatar
jon@work
No - you'd fuck the transfer box up
Old Nov 12, 2006 | 12:48 PM
mustang 390
How about if i just remove the front drive shafts then.
Old Nov 12, 2006 | 01:21 PM
DazC's Avatar
DazC
You'd still fuck your transfer box up as you are doing exactly the same as removing the front propshaft - removing the loading off the the front drive train alowing the diff to spin at unequal speeds from front to rear.
Old Nov 13, 2006 | 09:13 PM
BOBXR4X4's Avatar
BOBXR4X4
Prob woulnt go very far or very fast either
Old Nov 22, 2006 | 09:50 PM
MICKY84's Avatar
MICKY84
Default 4x4 to 2wd
you need to change the gearbox for a borgwarner t5 from 2wd with the mount and propshaft and remove the front drive shafts. leave the cv joints bolted in though or the wheel bearings will colapse! or just buy a 2wd cos
Old Nov 23, 2006 | 02:28 PM
Mr 19"'s Avatar
Mr 19"
Or use an MT 75 2WD gearbox as i did.
Oct 9, 2015 07:38 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 15, 2015 06:24 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Vincereese
Aug 11, 2015 08:44 AM
