Clutch!!!
Old Nov 11, 2006 | 01:53 PM
dee00's Avatar
dee00
Default Clutch!!!
was just going to change my clutch from a standard RS Turbo clutch to a AP organic, Guy told me that i might have to change the quaderen???
Help!!!!
Old Nov 11, 2006 | 03:44 PM
Chris69's Avatar
Chris69
the pedal quadrant mate
AP reccommend u change to a mk6 peal with manual adjustment- you then use a different pedal quadrant/ratchet to match up with the pedal
Old Nov 11, 2006 | 05:06 PM
SafeChav's Avatar
SafeChav
As said, its recommended but not essantial.
But by changing the quadrant you will:
1. Lose all chances of the auto adjuster ever failing (which they often do)
2. Be able to adjust the pedal height to suit your needs
3. Have a lighter pedal and also will get a higher lift on the pressure plate
Not really anything good about keeping the old one apart from they are a pain to fit
Old Nov 11, 2006 | 06:35 PM
GUZZLER's Avatar
GUZZLER
it is essantial on some cars, some are ok but some suffer with bad drag etc with a standard pedal/quadrant
the conversion is not hard to do, dosn't cost a lot (about Ł25) & its a lot easier than re-fitting a standard quadrant
Old Nov 11, 2006 | 08:38 PM
Rick's Avatar
Rick
As Guzzler. IMO, it IS an essential conversion. And it is so much nicer to drive.
Old Nov 11, 2006 | 10:26 PM
notSteveS2's Avatar
notSteveS2
on my car u have to push ya finger up behind the pedal and push a little catch to release the cable... is this standard or mk 6???
Old Nov 12, 2006 | 06:25 PM
dee00's Avatar
dee00
what quadrant should i get ?
Old Nov 12, 2006 | 07:24 PM
SafeChav's Avatar
SafeChav
You need to order a MK6 escort quadrant, 58mm NOT 55mm, and it shoud be white in colour, NOT black, and a MK6 pedal.
Old Nov 12, 2006 | 07:55 PM
dee00's Avatar
dee00
cheers mate, but is it somthing i have to do or could i get away with just fitting the clutch and not changing the quadrant, what would happen if i dont change the quadrant......???
Old Nov 12, 2006 | 08:12 PM
SafeChav's Avatar
SafeChav
Read what i said above, that says everything you will gain over the old one......
Old Nov 13, 2006 | 07:31 PM
JesseT's Avatar
JesseT
How can you get more clutch travel AND a lighter pedal?
I'm at least using the standard mk3 quadrant with my AP and have absolutely no issues with the pedal. The clutch could take some more torque tough...
Old Nov 14, 2006 | 01:24 PM
SafeChav's Avatar
SafeChav
The pedal is lighter, because you are using a larger diameter Quadrant, the same way its easier to undo bolts with a ratchet with the longest handle possible
And you get more lift also again because the quadrant is a larger diameter, it has a larger circumference so it pulls more cable when fully depressed
Old Nov 14, 2006 | 03:12 PM
Rab's Avatar
Rab
Fucking superstar........
Listen to him, he's a smart lad!
Old Nov 14, 2006 | 03:19 PM
SafeChav's Avatar
SafeChav
Gosh.....i feel all spesh now lol
Old Nov 14, 2006 | 04:15 PM
John Laverick's Avatar
John Laverick
In-correct......
As JesseT says you can't have BOTH increased clutch travel AND a lighter pedal.
The imposed load into the system is not directly applied to the Quadrant lever but to the pedal arm. The output is related to the lever arm ratio.
You can have either a lighter pedal and less stroke OR a stiffer pedal and a longer stroke.
It is possible to prove by moment equations but I'm not going to
Old Nov 14, 2006 | 05:32 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Here you go......
http://www.apracing.com/roadcar/clutch/epmods.htm
Takes some fiddling to get it right if you want the pedal to end up not being higher than normal, but worthwhile IMO.
My Alcon 6-Paddle feels SO nice to drive with.
Old Nov 14, 2006 | 09:30 PM
SafeChav's Avatar
SafeChav
In-correct......
Indeed, spoke Jesse online immediately after and realised this
So i take it back
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
