Turning up boost
Old Nov 10, 2006 | 06:27 AM
iancseries2's Avatar
iancseries2
Default Turning up boost
this probably gats posted quite a lot but i want to turn up the boost on my s2, i dont want massive amounts prob bout another 3 or 4 psi. i just need to know what way i have to turn the actuator rod and by how much! any helkp would be much appreciated.
Old Nov 10, 2006 | 08:44 AM
Alvyn's Avatar
Alvyn
I'd say IF you dont know DONT do it as there's more to be done than just turning up the boost by the actuator!
but if you must by lengthing the rod=less
Old Nov 11, 2006 | 04:13 PM
LuiPoland's Avatar
LuiPoland
pressure type(ball and spring) manual boost controler is a better idea
you can regulate boost very fast and easy, and what is important boost rise faster, so car can be faster even on standart boost, it give more torque at low rpm
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
