wire ringing
Old Nov 8, 2006 | 09:42 PM
fudgy's Avatar
fudgy
Default wire ringing
is this wire ringing could anyone advise me on what type of head gasket for rebuild and where to get it
many thanks
Old Nov 11, 2006 | 12:19 PM
Alvyn's Avatar
Alvyn
If it's just the thin line of wire in the top of the block then you are limited to using a Group A gasket(WILL NEED THE WIRE CHANGING ALSO) or you could have the block re faced and then you could use WHATEVER gasket you wanted to use!
the latter would mead having the pistons machined down also!
Old Nov 17, 2006 | 07:49 PM
fudgy's Avatar
fudgy
was no wire ring in it was cosmetic metal gasket on it
thinking of total rebuild wat pistion's u think i should use
330bhp would be as much as i need
were u think i should buy the parts
many thanks
more photo's can be found at www.northcoastcruisers.com in the forum so sign up take a look at my progess
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
